Distributor not turning
Old Mar 10, 2004 | 03:38 PM
newstang's Avatar
newstang
Question Distributor not turning
I just purchased a 94 e150 with an inline 6. I have no experience with this engine at all.
I purchased it with the PO saying it was a no start because of the computer.
so I checked for spark, No spark. I then replaced the ign. module and coil, still no spark.
Then like a shmuck, I checked what I should have checked first, the distributor. crank, no spin.
Usually I would instantly blame a timing chain, but I hear this only has gears, no chain.
What is the likelihood that this is a broken gear?
Possibly the rotor gear pin?
also if anyone has an exploded view of this engine so I can get a visual, I would much appreciate it.
thanks
Old Mar 10, 2004 | 06:48 PM
ftwfred's Avatar
ftwfred
It could be a sheared pin in the distributor gear or the cam gears could be stripped or missing a few teeth... The cam gear is a nylon coumpund type gear and the teeth can strip..
I suggest you pull the Dizzy, Check the shear pin in it and try to visually see if the cam is rotating..
ftwfred
Old Mar 15, 2004 | 09:29 PM
speedwheeler's Avatar
speedwheeler
mine sheared the pin and dropped the gear it threw me until i tried unscrewing the rotor dont drop the gear in the pan like i did
Old Jun 20, 2004 | 11:21 AM
tikler's Avatar
tikler
I just bought an '81 and have the same problem. When I try to turn the rotor by hand it wont turn that way either. Does this mean its the cam gear? I'm an old Pontiac v-8 guy so I have no idea how the distibutor down low on the side of the motor is driven by the cam gear. Did anyone have an exploded view of the motor. The Haynes manual I bought doesnt discuss how the distributor is driven anywhere I can find. Thanks, Tommy
Old Jun 20, 2004 | 09:38 PM
tikler's Avatar
tikler
Talking
Anybody here?
Old Jun 21, 2004 | 12:28 AM
stractor's Avatar
stractor
Tikler-- the distributor is driven from a gear that is part of the cam shaft. The dist shaft has a gear pined to it and also drives the oil pump. You may have a bad timing gear. Pull the valve cover and see if the valves move when the engine is turned by---- HAND---, don't try to use the starter as I am not sure the valves clear the pistons at TDC if one of them is open due to a stripped timing gear. You won't have to move the crank far to tell if the valves move.
stractor
Old Jun 21, 2004 | 02:29 PM
tikler's Avatar
tikler
Thanks stractor. I'll give that a shot. I always wanted one of these trucks and I'm determined to get this one running again.
Old Jun 23, 2004 | 09:45 PM
tikler's Avatar
tikler
Update
Ok. Thanks for everyones help. All info led to pulling the timing cover and sure enough, plastic cam gear with 10-14 missing teeth. I have bought a gasket set and a set of steel gears. The crank gear has screw holes for a gear puller but I dont see how the cam gear is supposed to be pulled without damaging the cam. Also, what holds the thing on? There is no bolt. I'm fairly sure this is a stock setup so I guess it's pressed on? Any tips on this procedure would be greatly appreciated. Thanks, Tommy
Old Jun 23, 2004 | 11:09 PM
stractor's Avatar
stractor
tikler--- do a search under my name and you will find the info you seek-- the date should be some where around this time last year.
stractor
Old Jun 24, 2004 | 02:11 AM
checkyoursix's Avatar
checkyoursix
I would still pull the distributer out and check the teeth on the gears to make sure they are ok. I replaced my timing gears after they exploded and then two months later the distributer gear blew up. I replaced that and then the gear on the cam broke and had to replace the timing gears, cam, oil pump and the distributer. Things like that really p!ss people off. It is really worthwhile to check.
Old Jun 24, 2004 | 01:48 PM
wtroger's Avatar
wtroger
What every you do make sure and recover the broken teeth. There is nothing that can plug an oil screen or jam an oil pump faster the the teeth from a timing gear.
Old Jun 24, 2004 | 02:45 PM
tikler's Avatar
tikler
Roger that men. I'll take care of those things as prescribed. Thanks much, Tommy
Old Jul 3, 2004 | 08:52 PM
tikler's Avatar
tikler
Thanks to all who've helped me with my truck. I finished the job last weekend and shes been fine since. God help me, I love my truck!
Maine 1977 F100
Mar 19, 2015 05:45 PM
banks0531
37
Sep 3, 2014 08:45 PM
blueovalpaul
32
Jan 13, 2012 08:31 PM
Fourbee
31
Aug 28, 2011 07:39 PM
Dannym
Dec 12, 2004 06:53 PM
