Audio Tach
Old Aug 15, 2009 | 06:23 PM
F-250 restorer's Avatar
F-250 restorer
Audio Tach
Does anyone know how to get rid of the engine noise coming thru my radio, even when the radio is 'off'?
I have a 1975 F-250, and recently converted to a late model ('94) high amp alternator and MSD ignition with an MSD TFI coil. It sounds like the heater fan is running, but it is not. The sound is coming thru the speakers.
Cheers.
Old Aug 15, 2009 | 08:15 PM
Volvo92906's Avatar
Volvo92906
Ground it.......?
Old Aug 15, 2009 | 11:33 PM
johnboy427's Avatar
johnboy427
You need to run plug wires with RF surpression. The high voltage discharge will create a radio signal that will create a pop when each plug fires, and you get to listen to a very annoying buzz. Pulling power directly off the alternator for your head unit can cause this too but is much less common.
-Johnboy
Old Aug 16, 2009 | 10:00 AM
BigBlue88's Avatar
BigBlue88
Spark plug wires shouldn't be creating enough RFI to drive 4-10 ohm speakers all by themselves- (you'll hear from the FCC if they are!). I've heard spark-plug/radio interference before- but that's coming in through the antenna and high-impedance input stages on the amplifier as broad-band RF.
If you had a bad ground somewhere, or a partial short, or mixed up wiring somewhere, or a partially bad alternator regulator, or bad winding on the alternator, that would be more believable. Turning your radio off disconnects input power to the amp circuit (although perhaps "only sort-of" on modern radios that have a "power/standby" button instead of a physical off switch), but doesn't disconnect ground. If your ground "voltage" (supposed to be 0VDC) were "fluctuating", it could be back-feeding into the amplifier output capacitors, causing current to flow through your speakers.
Easy summary: I think you should double-check your wiring and test the alternator & regulator.
With the engine running, grab a multimeter and you should see about 13-14VDC from your alternator, and 0VAC. If you have any sort of AC voltage beyond a few millivolts, I'd suspect the alternator and/or regulator.
MJMETHOW
Sep 14, 2011 08:47 AM
Khauler
13
Jan 31, 2011 10:28 PM
JefflovesF250s
13
Oct 4, 2009 07:48 PM
Lee 78F250
Dec 14, 1999 06:11 AM
