gas cap
Old Aug 8, 2009 | 01:27 PM
travelingtom's Avatar
travelingtom
gas cap
i was just wondering if the gas cap could possibly be the cause of my truck shutting off. i have never heard of this before. my truck only shuts off when it gets warmed up, and when it stalls, it takes about five minutes or more before it will start back up.could it also be vapor lock? i replace the fuel pressure regulator and fuel filter, but it still shuts off. the motor has over 200,000 miles and still runs like a raped ape until its warmed up. any ideas would be greatly appreciated.
Old Aug 8, 2009 | 02:13 PM
fmc400's Avatar
fmc400
MSEE
Highly unlikely. What year is the truck?
Old Aug 8, 2009 | 03:14 PM
travelingtom
its a 1990, i also noticed the vent hose that comes off of the filler neck is plugged off.
Old Aug 8, 2009 | 06:55 PM
sixing's Avatar
sixing
I had an older van that did the same thing, turned out to be the ignition module, I replaced it with a cheap replacement that lasted about 2 days, I bought a motocraft replacement and never had any more trouble, I diagnosed it with a wet rag, as soon as it cooled off it started right up.
Old Aug 8, 2009 | 11:06 PM
76F100guy's Avatar
76F100guy
If you're running a non-vented cap (which you should be, on a '90), and the vent line off the filler neck's capped, that's your problem. To check, try driving without the gas cap on - not with a full tank, of course. If the problem's gone, you need to re-connect the vent line.
Old Aug 9, 2009 | 09:08 AM
travelingtom
ok, i drove the truck for about an hour with no problems and about a 1/4 tank. could i just get a cap that is vented? the filler neck hose on it was replaced with just a regular rubber hose that does'nt have the vent tube.
Old Aug 9, 2009 | 12:39 PM
76F100guy's Avatar
76F100guy
If you don't have smog checks where you live, that's definitely the cheapest alternative. Otherwise, you'll need to reattach the factory vent setup, which goes to the charcoal cannister under the hood.
Old Aug 9, 2009 | 10:47 PM
travelingtom
i will have to check that when i get off work, it started to do it again on my way to work today. it didnt stall out, but the rpm's started to jump around. i hammered the gas and it quit though.
Old Aug 12, 2009 | 09:44 PM
rikard's Avatar
rikard
Some of the early EFI 300s did have a vapor lock issue. The heat from the exhaust manifolds would cause vapor lock. Ford first used a small fan to cool the area then they installed a heat shield and increased the fuel pressure.
As stated by others a bad iignition module will often fail with heat.
regards
rikard
Old Aug 14, 2009 | 07:48 AM
travelingtom
i have a carberated 300. would i be better off putting that in?
Old Aug 14, 2009 | 08:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If your truck has the ignition module mounted on the dizzy, this is the worst piece of CRAP ever installed on any Ford vehicle!
(EDIT: I just looked the puppy up. This IS the same terd your truck has).
E43Z12A297A .. Ignition Module (Motorcraft DY425)
Fits 1990/91 4.9L (300); 5.0L (302); 5.8L (351W): E150/350; F150/350; U150 (Bronco) / Many other I-4, I-6, V6, V8 Passenger Cars/Trucks back to 1983.
After years of arguing, Ford was forced by the NHTSA to recall FIVE MILLION vehicles several years ago to replace them all.
I passed out over the back parts counter...an average of three of these fracatta modules a day...for over 14 years here in LA LA Land.
That's one partsguy at one dealership. Just imagine how many of these modules were sold during the same time frame at the other 5,000 dealers.
The three step scenario of a failing ignition module:
1) Module overheats, engine dies. Module cools down, engine restarts almost immediately.
2) Module overheats, engine dies. Module cools down, engine restarts in an hour or so.
3) Sooner or later, usually sooner, the module overheats, burns out. Now the engine will not restart!
Old Aug 14, 2009 | 10:06 AM
travelingtom
so your saying i need a new ignition module? and what is a dizzy? i noticed the other day that there is no gasket between the throttle body and intake. would explane why it idles high. but i still dont know why its dieing . if it is the ignition module, where is it located?
Old Aug 14, 2009 | 01:01 PM
NumberDummy
Dizzy = slang for distributor where the little darlin' is located.
I'm not saying you need an new ignition module, all I'm saying is the one on your truck is a major POS (Piece Of...you know what), notorious for failing.
Since your truck is cutting out after it warms up (and the module is prolly overheating in the process), replacing it...is a good idea.
Prolly 10 million of these exact same modules have been replaced since 1983.
Old Aug 15, 2009 | 01:13 AM
sixing's Avatar
sixing
Before I did anything, I would check for spark at a spark plug when engine is hot and won't start, this way you would rule out fuel problems if you aren't getting spark, then concentrate on electrical problems.
Old Aug 15, 2009 | 08:23 AM
travelingtom
put a new icm in it last night. seems to be running real smooth. only time will tell but i think i got it. thanks guys for all your help, could not have done it with out yah.
mikekfr
Mar 17, 2014 06:15 AM
Bill Kelly
Feb 2, 2014 06:33 PM
benbo30
Mar 14, 2012 03:58 PM
Flyin5
24
Jan 11, 2010 01:06 AM
Celtic Nomad
15
Sep 1, 2009 06:11 PM
