Has anyone ever used these setups on there engine?
I was looking at the dual two barrel carbs on a four barrel intake manifold adapter.
This would go on my clifford intake manifold.
Vintage speed web site sells the whole setup.
What do you think?
It will go on a 300 6 cylinder.
Reason: more info
The bling factor is def. high. Proper application I guess would depend on venturi/cfm sizes matched for your build. I'm sure a single 4v would be cheaper, easier setup though.
Most websites will advertise plug and play. I've spent many hours and $$ buying and tuning different jets to tune a "plug and play" Holley carb. The only way it is, is if they advertise that it's for a 300 I6.
That aside, it would definitely be different and a very cool setup to have on your engine! If you tuned it right, it'd be a lot of fun.
Believe it or not, one of the best 4 bbl carbs for fuel economy is the Quadrajet. It's small primaries and large secondaries give good throttle response and plenty of power. The secret to using a 4 bbl on an in-line engine is the put the primaries outboard with the throttle shaft parellel to the crank. If you have ever seen a Pontiac Sprint 6 you know what I am describing. Use a pre-emission, or no later than 69-70 Quadrajet. Unfortunately, only the 66 Buick Riviera 425 used an integral choke until much newer. If you use one from a Chevrolet, there is a small baffle around one of the secondary nozzles. You will need to remove it, it is there to correct a fule distrution issue at WOT on the Chevrolet manifold and will cause a lean condition on some cylinders.
Shouldn't be too difficult. Get some high temp gasket maker that can be used on manifolds (buy it by the roll, not very $$), and lay it over the opening and trace it. Then, go buy a piece of plate steel about 1/4" thick, lay the gasket over the top, mark your holes, and drill through.
Find some bolts that match and tighten the plate down with the gasket in between.
Probably $10 - $15 and a half hour of time minus collecting supplies.
With the coolant passage under the intake i am not sure if a half inch plate will fit.
I have halfway mocked it up to see how everything would go together.
There does not look to be even a half inch of room between the two manifolds.
Could I go with a thinner steel plate?
Has anyone tried this before on this type of intake/exhaust manifold before?
Thank you for all your input.
Vincent
That's a good point, if there isn't enough clearance. Even if you got thinner steel, the bolt heads might still be pushing up against the intake. Too thin, and the plate could warp under heat.
Could you simply have the hole welded shut?
