Distributer gear
Old Sep 25, 2011 | 11:11 AM
Davidwent's Avatar
Davidwent
Distributer gear
Is it a press fit on shaft? Is so any hints on getting it off if I don't have a press?
TIA
David
Old Sep 25, 2011 | 12:42 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
IIRC it's held by a roll pin.
Old Sep 25, 2011 | 01:00 PM
Davidwent's Avatar
Davidwent
Yeah I got the pin out and it isn't moving, and I really don't want to start hammering it yet
Old Sep 26, 2011 | 08:45 AM
Davidwent's Avatar
Davidwent
Sorry to bump this guys but still no answer and I rapped the gear a couple time with hammer and no movement
TIA
David
Old Sep 26, 2011 | 08:57 AM
AbandonedBronco's Avatar
AbandonedBronco
It's a pain to get it off, but it just takes force. Try prying it up evenly with two flat bladed screwdrivers. Just be careful not to press on parts of the distributor that bend.
If you do, you'll need to bend it all back in place. It's not hard.
I bent the plate once and didn't realize it and my timing would "stick" once it advanced. Easy fix, but it left me scratching my head.
Just be sure everything moves smoothly and the stator doesn't hit the magnet as it spins when you get it all back together and it's good to go.
Old Sep 26, 2011 | 08:58 AM
AbandonedBronco
In advance, getting the stator back on is MUCH easier. Just put a long socket on it and tap it down with a hammer.
Old Sep 26, 2011 | 10:10 AM
Davidwent's Avatar
Davidwent
Thanks so much AB!!
David
Dbass1292
Engine Swaps
Mar 3, 2015 02:31 PM
Hillcapper
May 7, 2009 10:05 AM
beartracks
Electrical Systems/Wiring
Sep 19, 2008 09:42 PM
websthes
Apr 20, 2005 08:39 AM
Kemicalburns
1978 - 1996 Big Bronco
Oct 23, 2003 09:27 AM
