EGR
Old Sep 20, 2011 | 08:13 PM
kedwinh's Avatar
kedwinh
EGR
What effect will a non working EGR have on my 85 TFI/Feedback motor? It doesn't hold vacuum but doesn't appear to leak either and the little solenoid on the valve cover that goes to it doesn't work either, from what I can tell. The motor seems to start and run great.
Old Sep 20, 2011 | 08:39 PM
Galendor's Avatar
Galendor
When your truck is warm and idling, reach a finger behind the EGR valve and gently push in the valve plate a little bit. When you do that, your engine should stutter and almost stall. If so, that is an indication that it may be working perfectly fine. It is only supposed to open with a warm engine at significant throttle, injecting exhaust gas into the combustion stream when it really won't hurt performance (and may just help a little).
Old Sep 22, 2011 | 02:15 AM
kedwinh's Avatar
kedwinh
I don't think it's frozen it just wont hold any vacuum when I hook my little vacuum pump up to it. So, beings it is suppose to only work when up to temp and cruising speed, how do you go about testing the valve and relay that controls it?
jeep8589
1978 - 1996 Big Bronco
Nov 8, 2007 12:21 AM
1986 bronco eb
Mar 1, 2005 10:34 PM
andym
Oct 3, 2004 06:36 AM
WoodworkerJon
Apr 18, 2004 08:46 PM
fiend
Oct 23, 2003 09:52 AM
