95 e250 with 4.9l won't start after shutting off - Ford Truck Enthusiasts Forums
Old 09-27-2011, 08:59 PM
t mango
t mango is offline
t mango is starting off with a positive reputation.
I have 95 e250 with 4.9l motor, van has 215346 miles on it. It starts up & runs but recently it started idling fast & when you shut it off it won't stared unless you let it sit for 12 hours or more. It acts like it is flooded. I was thinking that it might be the IAC valve. I would appreciate any advice...tony
Old 09-27-2011, 09:24 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
octaneforce is starting off with a positive reputation.
possibly a fuel pressure regulator gone very bad? have you tried pulling the codes?
Old 09-28-2011, 06:06 PM
t mango
t mango is offline
I haven't pulled the codes since this problem started. I put a new fuel pump in it last year & pulled the codes at that time. The only code was for the o2 sensor. I plan on pulling the codes again but I've got good information from this site before so I thought I'd try this site first.
Old 09-28-2011, 10:03 PM
octaneforce
yep, lots of great info. if you can pull the codes that will make it so we can provide even more info!
Old 10-15-2011, 06:45 PM
t mango
t mango is offline
Pulled the codes & the O2 sensor code is still showing up but that has been showing up for while & the van was running & starting, I did change the IAC control but it didn't solve the problem. I stated the van was acting like it was flooded but that wasn't correct. It just won't restart after shutting it off unless it sits for hours. Any suggestions??
Old 10-15-2011, 07:24 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I'm gonna guess ignition module, coil or distributor pickup mechanism (my bet is on the module).
I'm not sure on those EEC IV things, parts stores might be able to test them, give them a call and see.
Do a google search on testing the ignition coil and distributor pickup.
Old 10-15-2011, 07:51 PM
fordman75
fordman75 is offline
fordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to behold
Does it turn over but not fire or does it not want to turn over?
Old 10-18-2011, 08:33 PM
t mango
t mango is offline
It starts up & runs fine but will not restart unless it sits for a few hours. It turns over but will not start . I thought I might have a leaking injector causing the problem so I pulled the spark plugs to check for fouling but they look good.
Old 10-22-2011, 05:41 PM
t mango
t mango is offline
I changed the Air Charge Temperature Sensor & the problem appears to be corrected . I wasn't getting a code for the sensor but I had stopped by a local ford dealer & the service manager was kind enough to point me in the right direction. I will post an update if the problem reoccurs.
Old 05-31-2015, 01:28 PM
airman312
airman312 is offline
airman312 is starting off with a positive reputation.
Help T Mango!!!!!! Where is the air charge temp sensor located?? Have a new one but cannot find the old one. We have the same year and motor
Old 06-01-2015, 09:45 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
ZarK-eh is gaining momentum as a positive member of FTE.
It's located in the front Cylinder 1, lower intake manifold.
Old 06-03-2015, 07:36 PM
airman312
Is the air charge temperature sensor the same as the intake air temperature (IAC) sensor?
Old 06-03-2015, 07:39 PM
airman312
Looking at the Chilton's book for full size vans..it calls it the intake air temp (IAC) sensor. Does this sound right?
Old 06-03-2015, 10:35 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Most likely yes, that's what they're referring to.
I really don't like it when multiple terms get used for the same component, that's irritating...
In my mind, IAC is Idle Air Control and it's a motorized unit that controls the engine's idle speed. That air charge sensor thing is what measures the temperature of the incoming air; the best way to verify if it's the same is to look at the electrical connections and the colors of the wires that feed it (and compare to a factory wiring diagram) but that's not always easy information to find...
Tabiks
07-21-2017 12:25 PM
Terrymiddlebrook
02-17-2017 08:22 AM
Wildrebel69xxxx
04-26-2016 05:58 PM
qrguiles
05-04-2012 09:29 AM
lillbro11
19
07-22-2009 04:04 PM
Quick Reply: 95 e250 with 4.9l won't start after shutting off
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
