refresh me extra quart oil filter number
Old Sep 28, 2011 | 12:48 PM
IowanStraight6's Avatar
IowanStraight6
Question refresh me extra quart oil filter number
i am back to driving a i6 part time long story nd its oil time whats that longer oil filter part number motorcraft number would be apprechiated thanks guys
Old Sep 28, 2011 | 01:18 PM
GHeTTo JOe's Avatar
GHeTTo JOe
Originally Posted by TallPaul
Thanks ceetwarrior. Did you know you can increase your oil capacity with a bigger filter. Try the FL299 or equivalent (spec for '89 F700 460 V8 I am told). The FL299 is 7 inches long and holds about a quart vs the FL1A's 5.4 inches and 26 ounces. Adds a little more capacity and filtration, and looks great hanging off the side of our big sixes! Usually have to go to a truck dealer or NAPA as run-of-the-mill chain parts stores won't carry them.
does this sound right
Old Sep 28, 2011 | 01:33 PM
nevrenufhp's Avatar
nevrenufhp
Napa number is a 1773.
Old Mar 12, 2012 | 06:56 AM
95E150-'rustbucket''s Avatar
95E150-'rustbucket'
long oil filter
Fram PH977A
Old Mar 13, 2012 | 03:03 AM
jem44357's Avatar
jem44357
I would not use fram.
Jim
Old Mar 13, 2012 | 01:51 PM
95E150-'rustbucket'
re: Fram
The preference for a particular brand of filter is very often personal. Everything I've read says that FRAM is an adequate filter; not great, certainly, but not useless, either.
On a personal note: in 1978 I bought my first car---a 1964 Corvair. Being a Chevy product, the recommended filter (a bolt-on unique to the engine) was of course AC-DELCO. By 1979 however, AC had stopped manufacture/acquisition of the filter; the only ones available were NOS, and the various part houses started charging at least double for it! All of the other filter manufacturers, except FRAM, followed AC's lead and slowed, if not stopped, manufacture. For the next several years, the only one available in wide distribution was the FRAM. I got the car with 110K on the clock and put over 190K additional on it, and when I sold it, it was still running on FRAM's. Eventually, an enthusiast aftermarket supplier came up with an adaptor for spin-ons, which obviated the need for the much more difficult to find standard filter.
However, the reason I posted the FRAM part number is as follows. All of the aftermarket distribution venues that have reference materials, catalogs or part look-up mini-puters (like Wally-World), sell FRAM, and the reference unit is usually their's as well. All have cross-references available to the FRAM number, if you have a preference for a different brand!
Old Mar 13, 2012 | 03:22 PM
tiap's Avatar
tiap
The regular Frams aren't very good, but the HP racing filters are very good and usually cheaper than the long ones.
The best thing I did was use a remote mount and have the filter in a verticle position. On several different brands of filters, on long "on or off ramps" and at start up the engine would clatter a bit, probably because the drain valves in the filters were failing. Once in the upright position, that never happened again.
BTW, I got the remote mount for two filters and I just get the 5" long ones since they are available everywhere and two are cheaper than the one longer filter anyway.
Old Mar 13, 2012 | 08:54 PM
95E150-'rustbucket'
re: remote vertical
mouth up or mouth down?
Old Mar 13, 2012 | 09:17 PM
Galendor's Avatar
Galendor
Longer filters equivalent to FL1-A are:
Wix 51773
NAPA 1773
Puralator L40017
Motorcraft FL299
Old Mar 13, 2012 | 10:41 PM
882tank's Avatar
882tank
Since this thread has already been brought back to life...Does anyone know if the FL299 actually has an anti drain back valve like the FL1A's? I've stayed away from running them on mine since I couldn't get a definitive answer.
Old Mar 14, 2012 | 12:54 AM
tiap's Avatar
tiap
Old Mar 14, 2012 | 01:49 AM
882tank's Avatar
882tank
Now that's definitive. Thanks Tiap. Time to give one a try.
Old Mar 14, 2012 | 02:55 AM
jem44357's Avatar
jem44357
Just to clarify. I put a Fram on a 302 I had years ago. This was the first time not using Motorcraft on my Fords... it blew the seem and dumped all of the oil and by the time I shut it down it took out a couple of main bearings. On my 93 F150 4.9 I took it in for a Penzoil oil change. They put a pretty bright yellow filter on it. At start up when cold it would clatter. A mechanic friend of mine said to switch back to a Motorcraft. Once I did the clatter stopped. So from my personal experience and a bit of research I do nothing but Motorcraft on my Fords.
Jim
Old Mar 19, 2012 | 04:22 PM
towtractorman's Avatar
towtractorman
oil pan capacity
I am computer illiterate and new to ford 300 engines. does anyone know the oil pan capacity (with and without filter) of a center sump oil pan ? Any help is greatly appreciated. also, i can only guess as to year model. probably 1968 or 1981??? thanx much
Old Mar 20, 2012 | 07:52 AM
jem44357's Avatar
jem44357
I think all 300/4.9 and probably 240's are 5 quart for stock pans and 1 for the stock filter.
