what is this...?
Old Feb 16, 2013 | 01:36 PM
Duke78's Avatar
Duke78
what is this...?
Replacing vacuum lines and looking to rebuild/replace the carb...when urn bolting the carb I noticed this tube fell apart? What is it for and should it be this way?
image_zps12c87c52.jpg Photo by Flemingtb | Photobucket
Old Feb 16, 2013 | 02:20 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
It's a small picture, but it looks like the leftover from what used to the the choke heater tube that runs to the exhaust manifold.
Old Feb 16, 2013 | 05:00 PM
Duke78's Avatar
Duke78
It does connect to the manifold. What does it do and its broken is that ok?
Old Feb 16, 2013 | 05:25 PM
BaronVonAutomatc
The choke system uses heat from the exhaust to operate. Even the electrically assisted chokes used on later model vehicles use exhaust heat. That tube carries hot exhaust to the choke. If you want the choke to function properly (or at all if it's not an electrically assisted choke) that tubing needs to be replaced.
eradicator006
16
Feb 5, 2018 07:38 PM
Funke1
Apr 3, 2016 09:16 PM
Dad&Son&F100
Feb 15, 2015 02:25 PM
tkisling
Jun 28, 2013 04:14 PM
ole yeller 1978
May 13, 2006 10:16 AM
