Howard's 263 cam (via Summit)
Old Feb 13, 2013 | 05:19 PM
F-250 restorer's Avatar
F-250 restorer
I'm about to buy this cam and lifters. Has anyone used Howards? I've read they just bought some impressive machinery, and are gearing up for greater volume production.
It is almost identical to the Isky 262. Amazes me how different cam co's write the power band numbers. I guess that is why athletes don't write their own press.
Old Feb 13, 2013 | 06:33 PM
Harte3's Avatar
Harte3
Power band numbers? Well, if nothing else they can be used for filler in the brochures
That company has been around since heck was a pup.
Old Feb 13, 2013 | 07:55 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Are you building a new engine or swapping out the cam you've got now? If you're swapping out I might be interested in buying your used Isky cam and lifters.
Old Mar 12, 2014 | 08:11 AM
dylansf23's Avatar
dylansf23
did you end up getting it?
Old Mar 12, 2014 | 11:31 AM
F-250 restorer
I'm still tossing it around. Pulling the cam means r&r the radiator and grill and I'm not sure I really want to do all that extra work just to have a lope at idle. But I might.
I'm still buying/finding/researching the porting tools and methods I will be using to remove the ridges from my combustion chambers and to clean up the runners. I also contacted SI valves about new oversize valves, the exact length as the oem ones--imagine that.
I will say that Howard's parkerizes their cams, and that is a critical step in cam production. That cam should be a good choice for a mild 300.
Old Mar 12, 2014 | 04:31 PM
dylansf23's Avatar
dylansf23
I'm seriously debating between their 209 and 213 cam. Leaving more towards the 209. I've been playing in desktop dyno and it yielded a little more trq down low
Old Mar 12, 2014 | 05:36 PM
Harte3's Avatar
Harte3
"it yielded a little more trq down low"
Where in the RPM band exactly is "down low"?
Old Mar 12, 2014 | 07:04 PM
dylansf23's Avatar
dylansf23
Under 2k. It should have the same peak numbers as the stock set up with a higher flow allowing another 500 so I can hit 4
Old Mar 12, 2014 | 07:10 PM
BaronVonAutomatc
As a general rule you're better off under-cammed vs. over-cammed. Especially in an engine that struggles to breathe anyway.
Old Mar 12, 2014 | 07:29 PM
dylansf23's Avatar
dylansf23
Exactly, and I want to still be able to tow. So it sounds good and does good.
Old Mar 12, 2014 | 09:49 PM
F-250 restorer
A hair past yonder.
Old Mar 12, 2014 | 10:08 PM
dylansf23's Avatar
dylansf23
Originally Posted by F-250 restorer
A hair past yonder.
Exactly! Haha
But seriously, would that cam still be strong at idle and up?
Old Mar 12, 2014 | 11:02 PM
F-250 restorer
Exactly! Haha
Howard's lists its power range beginning at 1200 rpm. Which means that when you hit the gas you'll never feel a lag.
Old Mar 13, 2014 | 11:49 AM
Harte3's Avatar
Harte3
"A hair past yonder"
Exactly! The term "down low" is highly subjective without a definition as to where 'down low" is and the way the term is used, misused and abused it is quite often meaningless.
Old Mar 13, 2014 | 03:15 PM
dylansf23's Avatar
dylansf23
How does your engine feel harte?
What rpm does it pull hard from til it stops?
