Need advice on camshaft
Old Feb 7, 2013 | 02:36 PM
maverick600's Avatar
maverick600
Hopefully this weekend I will be purchasing a 300 with a 4bbl intake with a 500cfm carb and exhaust header (dont have specifics yet). I will be driving up first to make sure truck runs and everything is good and then help remove emgine to bring home. The engine only has 50k miles on it. The most work my truck will be doing is pulling my boat that is kinda heavy so I am thinking of putting a cam in to help with torque and would like some advice on which one to get. I do not have power brakes so I dont have that vacuum issue to worry about. So there it is...please bring on the questions and advice PLEASE!!
Old Feb 7, 2013 | 05:09 PM
maverick600
Just ordered some 1.6 rockers with the kit so everything is new but I didnt think to ask about the nut size......damn
Just called back...should be good on that.
I looked up Comp cam and put in truck info and it suggested the 268 cam. As I was reading on another thread he was worried about losing some in the low end (torque?) with this cam which is what I am more concerned with as well.
BaronVonAutomatc's Avatar
BaronVonAutomatc
The Iskenderian Mil-A-Mor is probably as "max torque" as aftermarket cams come. The stock cam is good for low end as well, and some folks have used an adjustable timing set to advance the stock cam for even more low end. A little porting on the head and bumping up the compression ratio would also help.
Old Feb 7, 2013 | 05:11 PM
BaronVonAutomatc
With what kit? The stock rockers are 1.6:1, fwiw.
Old Feb 7, 2013 | 05:15 PM
maverick600
Kit meaning a new nut and the "ball" inside the rocker also.
Old Feb 7, 2013 | 05:17 PM
maverick600
I am going to have to learn all of the acronyms that people use in the forums. i have figured out alot of them but fwiw I have no idea lol
Old Feb 7, 2013 | 05:19 PM
BaronVonAutomatc
Ah so. Ford did use two different size rocker studs on the 300 through the years and the later models have bolt-down rockers in place of studs.
Old Feb 7, 2013 | 05:23 PM
maverick600
You got me....I am buying stuff in preparation. What I cant use I will be able to take back.
Old Feb 7, 2013 | 06:37 PM
Harte3's Avatar
Harte3
JMO the Comp 268 crosses the line from working cam to hot rod cam. Something like the Comp 260 is about as close to that line to get for a working cam.
Old Feb 8, 2013 | 12:38 AM
F-250 restorer's Avatar
F-250 restorer
X2 on the Comp 260. The 252 is great too. Isky offers a 256 for good torque and mpg. Schnider Cams has a couple of nice grinds too, as does Cower.
If you go to the Summit Racing site, they have a great article, 'Bump stick basics,' I believe, that does a good job of explaining the various aspects of a cam. It helped me.
Basically, and someone correct me if I'm wrong, the higher the duration (how long the valves stay open)the higher the power/torque band of the cam goes--meaning the more lower end you loose.
Old Feb 8, 2013 | 08:12 AM
68cabby's Avatar
68cabby
Sounds right f250. That's why I chose the 260. It showed improvements woo across the power band and bumped up the lower end instead of an emphasis on power or torque
Old Feb 8, 2013 | 08:43 AM
maverick600
Thanks F250 I will go there. I am guessing if I install these new rockers that they will help also and adjusting will be no different than any other?
Old Feb 8, 2013 | 09:46 AM
Harte3's Avatar
Harte3
I didn't lose anything with the Comp 260 but gained through the whole working rpm range.
FORDSIX PERFORMANCE • View topic - Will it pull?
Old Feb 8, 2013 | 09:55 AM
1986F150six's Avatar
1986F150six
maverick600,
If I may make a suggestion... put the engine in "as is". Who knows, it may do fine with whatever camshaft it presently has. If so, you save money and time!
Old Feb 8, 2013 | 09:58 AM
BaronVonAutomatc
As a general rule of thumb, every 10 degree increase in cam duration will move the peak power up ~500 rpm.
For low end torque the cam needs to maximize cylinder pressure - i.e. the intake valve closes early (near when the piston reaches BDC) so the piston moving upwards compresses the mixture as much as possible and doesn't blow it out the intake.
You can gain back the low end with a more radical cam by raising the compression ratio. Search for the timing cards on the different cams you're interested in and plug the info into a dynamic compression calculator. That will show you how the different cams will affect low end performance.
For a more or less stock 300 (or any engine with something like a new intake/exhaust but close to factory compression) it's better to under cam than over cam. In a truck especially I'd prefer to lose a little on the top end if it means extra grunt off the line.
