- engine swap 390 to 460
- 460 engine disasembly?
- 94 460 miss
- trouble starting 7.5L??
- EGR exhaust leak
- 1998 f700 speed control(governor)
- 460 FI swap / 514 build up? NEED HELP
- 429 plug wire diagram
- Checking Oil - How long do you wait after shutting off the engine?
- camshaft
- 460 install
- '73 429/c6
- '73 429/c6
- Cross threaded plug?
- 460 intake and headers?
- New and Improved
- Any suggestions on the build-up???
- 429/460 Intake Question
- 460 Timing Gear
- Pedastal or stud mount?
- Which Dip Stick tube to use????
- Weight
- looking for stump pullin torque
- 460 build
- Easily ID 460 engine
- Low Torque Cam Timing.
- Intake choices
- Anyone with MSD Ignition on a 460 non-TFI
- New carb..engine bogging down???
- Do roller rockers fit under stock valve covers?
