- 460 needs new carb
- Repairable? or do i need to buy a new block?
- which ignition module?
- Stock EFI 460 flow number?
- Oil leak again
- Need timing advise 460
- 460 heads and cam
- How long will a 460 motor last ?
- I love this photo...
- Starter trouble!!!
- 460 Lifter Specs.???
- 429 misses
- rebuilt 429 engine
- rebuild the rebuild blues
- High Idle Kit for a 460??
- Milling D3VE heads...
- C9VE vs. D3VE
- 460 timing sets?
- Reconditioned 460 engine
- Carb for 1983 460 in 1979 w/auto
- Low compression in #8 cylinder
- 460 mpg question
- Distributor Recurve Throwing Me A Curve!
- Water Pump Back Cover
- Any one used Comp Cams 252BH-10?
- 390 to 460 conversion
- Could I get a DD run, anyone?
- What Are The Affects Of Advancing/retarding A Cam?
- No spark HELP!!!!
- Newb Question bout' a 460
