- carb gasket sucked into intake
- Tuning Questions....
- Serpentine belt
- On the Autolite 4300 Carbs...
- Distributor, dual diaphragm vs single diaphragm
- Vortech supercharged 460?
- 460 hp/torque specs-1990
- timing for 429
- Broken off studs
- Hot oil
- Head casting #
- 1972 F250 2wd/auto 460 Headers
- engine swap
- Oil pump driveshaft
- 351W to 460. Need advice.
- Power not up to par
- Hydraulic roller cams??
- oil discoloration
- Motor mounts again
- Engine mounts & perches
- 460 vac. hose route question
- 460 conv.
- What cc are D3VE A2A heads.
- milling 460 heads
- 460 build up for 78 f150
- Engine ID
- 78 460 Engine and Tranny Questions
- spread-bore carb on 429
- HP and Torque on 460
- rear sump oil pan 460
