- 460 Finally in '67 F100--what shroud?
- 460 will not shut off.
- 460 push rod length
- Article on building a 540
- Stroker motor question
- RE:460 buildup
- R&R 460 c.i.d. rear seal
- 460 Octane booster?
- 88+ heads on older block???
- Replacement for a 460
- 429 w/serpentine belt system
- Oil pump drive rod question
- 460- 4 sp. to C6
- 520 into 77 highboy
- 370 firing order
- mysterious oil usage
- D3VE head milling
- exhaust pipe routing
- electric or manual choke
- 400 to 460 swap
- HELP my 460 failed the emmsions test need advice
- natural and gasoline question
- hard start, when hot!
- Speed Demon Carb on 460?
- 1987 460 lack of power and overheating
- D3Ve's smog humps
- bog at wot
- 385 Series Parts List
- 429 with tunnel ram
- Ignition Coil wiring
