- Another question??? RPM'S???
- How's a 460 suppose to sound?
- 71 2v heads vs 4v heads (429)
- 385ci???
- marine 460
- Bad knock in 460
- Question about starter interchange
- 75 460 wont start
- Performance failing--Why?
- 460 conversion
- where...
- Won't shift into 4th gear?
- Carbed to EFI conversion
- PLEASE HELP!!!!
- 460 Build Up Questions
- Kenne Bell TS2000 on a late model 460
- What were the differences Between theese two heads?
- Just bought a 1988 F-350 1 Ton 4X4 Engine???
- 370 same as 460?
- 460 Performance
- EFI 460 Manifold
- smogger cam with power?
- 460 Blocks
- 95 EFI 460 stock
- Water Neck for a 460 - GOING NUTS!
- which engine is best?
- Manifolds
- 97' 460
- Closed chamber D3VE's?
- rocker arm conversion??
