- 460 bare block and head prep
- towing 460 build up
- need pollution crap for 351 or 460 hoses etc
- 429 alternator belt
- 460 truck exhaust manifolds
- 460 manual flywheel identification
- Required vaccuum connections.
- oil sending unit
- Banks PowerPack
- 460 Silicon Hose Kits
- 10 qt oil pan, L&L vs 7qt.
- 1984 460 HELP!
- 1977 250 with a 429
- 460 Headers, 78 F-150 Ford 4x4
- Is an aftermarket cam worth the swap?
- 351w to 460(seriously)
- Timing Gears
- 460 Valve Train Problems
- 460 - sealing the water pump bypass tube
- stock cam specs
- 94 460 HP
- Can the oil filter adapter be removed easily from a van 460?
- Which factory 4-bbl. carb is better, Holley or Motorcraft?
- 460 using oil
- 460 CHROME dipstick - where 2 get?
- question about oil filter location on a 460 from a van
- Bad gas milage...vacuum question
- Gang; here's the RIGHT part number....
- 460 in an F150
- MSD Ignition on 97 460
