- Ignition cut-off, Backfire
- drag race suspension question
- Will 460 EFI heads bolt up to a carbureted 1972 429 engine?
- H.E.I. module
- 460 best years
- 850 CFM carb To small
- Stock intake weight?
- 370 CAST headers
- 1989 460 EFI Casting Numbers
- Ford Big Block casting #s
- A 429 Question
- 460 horsepower question
- dist. mech adv. plate
- 460 Build up
- 460 marine engines
- possible to build stroker with cheap parts?
- EGR plate??
- Stoopid question-460 EFI
- time to make it manual.........ZF 5 or 4 w/OD
- 429 Timing Question
- Straight up Cam timing
- 1996 EFI 460 mods, help!
- New valve covers
- 750cfm.. more or less??
- 460 rebuild questions
- 460 carb problems
- Easy replacement for Rail Rockers?
- 429/460 identification help
- 460 in 78 Bronco
- Distributor vs. Doofus
