- Here's the casting number, can you id this motor?
- Aftermarket engine brackets?
- Help MPG
- 460 price
- hi Mike, i send u a mail about the valves did u recive ?
- Engine size
- identifying speed density,or maf on 1997 f350 460 4x4 5spd
- hyper pistons and ring gaps
- clutch
- Looking at a '75 TBird 460????
- D2VE heads
- 460 in a late model F-150
- comp 268 in a late model 1997 efi 460???
- Vin number help
- 1992 460 Valve stem Seals
- Towing RPM
- 460 fuel milage?
- New To FTE, Need help with #'s
- clutch and flywheel woes...... need help
- Timing chain cover
- can anyone sell me valves for a 460 ´69
- heads
- 1997 f350 4x4 crew cab srw 460 5spd 4.10's
- first time ford owner
- Camshaft opinion
- electric cooling fans
- 460 Cam ID? #940048
- Still at it, where's the problem?
- Question on stock valve train
- T-56 behind a 429
