- Adjjusting valves
- Upgrade 429 or swap for 351m
- rebuilding 460 engine
- Adjusting valves
- radiator
- Oil Pan Modification
- 429 Rear main leaking
- 460 missing at mid RPM range
- 429 crank problems
- 1990 F700 Problems - Need Ideas
- lame first post 1st gear at 40mph now it makes engine noise
- Aussie Slang - By Jamies460
- what should i do with my 460?
- 1969 Lincoln 460
- Looking for 429 Solid Motor Mounts
- max cam lift???? 1978 stock 460
- max cam lift on stock 78 f-150 460
- 460 stalling around corners
- 521 A460
- Distributor Problems
- Ford 557 Stroker Kit
- Which Holley will Fit?
- Another 429 FI question
- Fuel Injection on 429
- 460 distributor gear shear
- How do you swap the oil filter adapter, 84, 460, 4wd?
- Oil filter adapter, 84 460, 4wd, how to swap?
- Where is the ballast resistor?
- 460 Heads
- how much hp and tq?
