camshaft
Old Mar 5, 2006 | 04:13 PM
shortbed1's Avatar
shortbed1
camshaft
Hi fellows,
I was looking for some help on cam selection ive got a 70 460 30 over flat tops ported, polished and gasket matched dove c heads 175 shot nitrous c6 2800-3000 stall with 30 gears. Have been looking at these 2 comp cam kits part# xe284h and xe 274h this truck is not driven dailey so i was looking for something a little more radical than what i have. I was also going to the sealth or air gap by edelbrock. any sugestions would be a great help thanks in advance
chuck
Old Mar 5, 2006 | 05:40 PM
monsterbaby's Avatar
monsterbaby
have you thought about going roller cam? more money but definatly more power too. other than that the comp xtreme series of cams are a really good cam selection but telling us what the truck is actually used for helps too.
Old Mar 5, 2006 | 06:21 PM
bigsnag's Avatar
bigsnag
I'd probably go with the bigger camshaft. I DD'd that combo and with the bigger cam you should be in the powerband from 2500-6000. At 2500 RPM's it's showing over 450 ft.lbs of torque and peaks at around 4000 RPM's. Max power is right at 5500.
As for the intake, the Stealth is a great choice, but the Air Gap is a good one too. Personal preference on that one.
Old Mar 5, 2006 | 06:50 PM
shortbed1's Avatar
shortbed1
Hey monsterbaby thanks for replying the truck is used for weekend drives hunting a few chebies. I also just love the power these bbf's make awsome. Might go to the local 1/8 mile track once in a while. Thanks for ya help in advance.
chuck
Thanks for the info bigsnag really appreciate it that cam does sound good.
Old Mar 5, 2006 | 08:17 PM
bigsnag's Avatar
bigsnag
If you are just looking for a weekend warrior type of truck, then I would also suggest a roller cam, if the budget allows. Crower has a nice roller that isn't too aggressive and keeps the max lift down so it's really easy on your valvetrain. Comp also has a couple of smaller solid rollers. I don't think they list them in their new catalog but they still make them.
http://www.compcams.com/Technical/Se...umber=34-770-9
http://www.compcams.com/Technical/Se...umber=34-771-9
The second Comp cam listed there would have just about the same exact RPM range as the bigger cam you listed. However, when I run it through DD, I get aover 100 more ft.lbs of torque and more than 100 more hp!!!!
Old Mar 6, 2006 | 02:48 PM
fordtruggy's Avatar
fordtruggy
I am running a comp 270 in my 466 and love it.builds power to 6k and has a rough idle.
Old Feb 8, 2007 | 01:20 PM
76cougar74100's Avatar
76cougar74100
i am also looking at the similar cams anyone know anything about the lunati voodoo cams? pn: 61603 and 61604
Old Feb 8, 2007 | 07:39 PM
79superduty's Avatar
79superduty
Post
the 280 is the better of the two 550hp at 5000 to 6200 and 550tq at 5000.thats similar to mine i stayed solid cause a little more streetable and less maint.you can race the roller but less freindly on street when you gotta lug it around sometimes .. voodoo great for hp.not too big on torque good in a light car
Old Feb 8, 2007 | 11:31 PM
76cougar74100
what do you typically look for when picking a cam?
Old Feb 9, 2007 | 01:02 PM
bigsnag's Avatar
bigsnag
Your cam is the most crucial choice when building an engine combo, IMO. It needs to be matched to all the other components and also needs to be suited for the intended purpose. A huge roller cam is no good for a daily driver that you need a lot of torque for pulling loads. Conversely, you wouldn't want a small RV type cam in your 557 cubic inch, aluminum headed, single plane manifold, weekend warrior engine that you plan on racing and revving to 6500 RPM's.
If you need any specific advice, let us know your engine and components and your intended usage and someone, including myself, can give you a few recommendations.
Old Feb 9, 2007 | 10:12 PM
79superduty
got that right thats' why mine is custom made ..... ford has some nice cams .write me back with what u wanndo and i'll try to help ..........
Old Feb 10, 2007 | 06:47 PM
76cougar74100
i want to keep the stock bottem end for now. the truck will not be doing any towing uless i buy a street bike to sit in the box haha. the truck will be used for taking down chevy's and dodges not daily driver.
racerx6466
Modular V8 (4.6L, 5.4L)
Dec 15, 2009 06:09 PM
78-250Super
Aug 20, 2007 06:32 PM
siphor84
Jul 13, 2005 12:24 PM
jwtaylor
22
Dec 17, 2003 03:50 PM
jwtaylor
17
Sep 6, 2003 06:32 AM
