- Misfireing on 1997 F460
- bent pushrods/bent valves
- Max compression ratio on pump gas
- need help tuning my 460
- Electric fan swap
- Getting the most out of a 460.
- Pushrod Guide plate Necessity
- Engine size question
- Timing question
- Getting 1996 F250 460 EFI
- 94 Ford 460
- Ticking/clicking sound - 97 : 460
- EFI 460 year confusion. Buying engine. Info needed.
- fuel pressure problem
- pulley kits
- need help getting engine project started
- 89 ford f-250 460
- 460 dipstick
- Are copper header gaskets a good idea?
- Nothing you haven't read before
- 460 Noisy Gear Drive
- 1996 460 EFI V8
- 460 Build Question
- building a 429 with hopes of 450-500 hp
- Mechanical Temp Gauge
- 460 Build help
- 460 and holley carb question
- Starter to flywheel contact
- 460 build advise
- 1996 460 Water Temp Sensors
