- 86 460 specs
- 460 tko 600
- Edelbrock intake???
- Need to get pointed in the right direction.
- 460 Might Be A Great Deal
- bad96
- valve size
- 460 Crank Specs
- Another Electric Choke Question
- Stock 4V manifold any good
- Questions for an efi 460 on propane
- Cheap 460 build,need some in put,
- Wanting to use 370 crank in D0VE 460 block.
- ford 429
- egr valve
- old school power new truck
- Duraspark, number one wire on dizzy is where???
- 460 Performance Power loss question
- fan clutch
- ???police interceptor 460???
- What Should The Oil Presure Be For A 351m
- can't find the miss
- I need some straight info on the 429.
- Ford 429 from a 97 F700
- Gas mileage tips
- increase hp on a budget
- can only get '96 460efi to rev to 3500 rpm
- efi460 timing?
- Carb Question
- Best Coil for Unilite Distributor in a 460 ...
