- Oil pump drive shaft came out of place
- Plug the fuel return line?...'85 460
- Cam Bearings
- Problem with Ford Racing valve covers on a 460...
- hyper. vs . forged
- 97 hyd. clutch cant get proper pedal
- 460 or is it?
- Cam Bearings
- New 460 overheating problem
- 460 rebuild: what brand names to use
- Destroyed lifters and cam
- DOVE head volume?
- 88 E350 460 w/busted exhaust manifold bolts
- 97 ford
- 429 thunder jet
- 460 in C class motorhome
- Any tips for getting old lifters out of the bores?
- Heater hose hook up
- 460 Headers
- Any help with exhaust headers would be appreciated.
- Is there a difference between the diff years of 460's?
- factory hpipe
- header application
- Warning Against using API grade SM for camshaft breakin!
- Eagle SIR Conecting rods
- cracked block, repair
- 1988 E-350 Cabriolet
- 429 build for towing
- 385 in a 74 Crew 4X4
- input ideas for a 460
