- 460 timing issue
- Compression Question??
- Motor stumbling
- 429-460 Dual Quad Intake wanted new or used !!
- ring gap- aftermarket pistons(460)
- BBK dual 65mm TB?
- coupple quick 460 questions
- Need a new 4bbl intake for my 429, which one?
- 460 Hard Start
- Where is the fuel pressure test port?
- 429 Exhaust manifold, gasket or high temp Sealant??
- Electric Fan
- 460 cam swap-high miles
- 460ford site help
- Intake for truck pulling
- Oil Pressure
- Opps.timing set
- My 460 Build - Need Alot of Help! (PICS)
- valve noise on start up
- Lubrication upgrades for the 429/460 block
- Buying a 460 on Sat. morning
- 385 Series Heads
- Building a 460
- I drink way to much gas
- Need some help guys
- Swapping in a 460 in my 79 f350 4x4
- alternator
- 460 towing mods
- clutch and flywheel problems
- Pushrod length checking
