- Problems with my timing? Carb backfires on occassion?
- 1988 Ford E350 Van/Bus
- Stock intake
- need help finding a flywheel
- 460 crank in a 429
- D0OA-E?? Rods
- Aftermarket Programmable EFI on a 460?
- Dual Quad Intakes for 460s?
- need some of your input on this
- Need help with "pinging" `92 460.
- Valve length ???
- Vacuum
- stock vs. aftermarket ignition setup.
- Cold-air system for `92 460??
- Timing mark jumps around - can't set timing
- whats the best year for 460
- should i buy a 460
- 429 or 460????
- 429 ????
- how much oil for 89 f350 with oil cooler?
- Is a 600cfm carb too small for a 460?
- water pump
- Vacuum?
- EFI pistons into a Thunderjet??
- Hey Deen...
- c9ve-a heads
- Straight up or Advanced
- Stock 460 cam specs.
- Engine ID
- summit brand lifters??.....
