- EFI pistons in a '78 block
- Rust in Cylinders
- 1996 F250 exhaust system question?
- new pull motor for f350
- Overdrive Light Flashing?
- Help changing belts on 460.
- Big truck 5 speed in F-250
- 460 oil pressure question.
- cam and intake question
- Is head gasket right?
- Number of bolts holding tranny to engine block?
- Carburator size?
- 1994 460 vacuum devices on coil bracket???
- 1996 460 fuel encomy upgrades!!!!
- sparkplug threads
- 3 Circuit Dominator Carb....
- Stripped out oil drain plug in 460
- 385 series books
- 89 460 EFI hesitation when accelerating
- 460 Worth it
- 285,000 Miles on a 460
- Help, leaking coolant
- Starter won't engage fly wheel
- Block Casting to ID engine help?!
- Air Injected Or Not - How To Tell
- rear sump pickup arm nut size
- recurved distributor
- 460 Trans ?
- black soot out of tailpipe.
- 3 bent cams, 3 different stores. . .
