Easily ID 460 engine
Old Feb 28, 2006 | 02:10 PM
HonorableKingCab's Avatar
HonorableKingCab
I'm looking to purchase a '78 or '79 F-250. The owner died in January and her kids say that it has the 460 ci in it. I don't really want to take their word for it.
What is an easy way to identify the engine that's in this truck?
Thanks!
Old Feb 28, 2006 | 02:44 PM
monsterbaby's Avatar
monsterbaby
8 bolts on the valve covers, and thermostat housing on the intake manifold are too easy give aways. But the Windser motors also have the thermostat housing on the intake but the size difference should be obvious for that plus they don't hve 8 bolt valve covers.
Old Feb 28, 2006 | 10:08 PM
Bill_Beyer's Avatar
Bill_Beyer
If it's a 4X4 and the engine is original then it's not a 460. If it's a 2wd then it could be a 460. Easiest way is to check the VIN.
Old Mar 1, 2006 | 12:17 PM
Brad Johnson's Avatar
Brad Johnson
Take a peek under the coil hold-down clamp. Unless someone removed it there should be a small metal tag there. The first number stamped on it is the displacement.
If you are lucky, there may be an engine tag that's till readable enough to see the displacement. It will be stuck somewhere on the top of the radiator core support, or possibly even the top of the valve cover.
Brad
Old Mar 3, 2006 | 01:15 PM
fordtruggy's Avatar
fordtruggy
Originally Posted by monsterbaby
8 bolts on the valve covers, .
My 460 doesnt have 8 bolts it only has 7 for the valve covers.?????
Old Mar 3, 2006 | 01:22 PM
monsterbaby
my bad your right I must have been half asleep when I wrote that, ok don't listen to me.<a href='http://www.smileycentral.com/?partner=ZSzeb008_ZNxdm824BXUS' target='_blank'><img src='http://smileys.smileycentral.com/cat/4/4_18_5.gif' alt='Bag Head' border=0></a>
Old Mar 3, 2006 | 01:25 PM
Bill_Beyer's Avatar
Bill_Beyer
You're correct. I think monsterbaby had a brain fart. Clevelands & 351M/400s have 8 bolts. 429/460s only have 7.
Old Mar 3, 2006 | 02:35 PM
quehele's Avatar
quehele
Check the head casting numbers between the exhaust ports. '78 and '79 should have D3VE heads.
Old Mar 3, 2006 | 04:09 PM
385seriesHemi's Avatar
385seriesHemi
I have 2 '79 460 engines and both sets of heads have D8VE on them
Old Mar 3, 2006 | 04:18 PM
monsterbaby
You better look again I bet you wil find that that 8 is actually a 3 there is no such thing as a D8VE head casting. I might make mistakes once in awhile but that one i don't make a mistake on.
Old Mar 3, 2006 | 05:05 PM
385seriesHemi
yea, it looks like a 3 now since i just got done cleaning it off all the way.
Old Mar 3, 2006 | 05:39 PM
banjopicker66's Avatar
banjopicker66
Also, look at the thermostat housing.
460 thermostat (not the housing) lies parallel to the ground.
351W and the 302 (I think) thermostats are perpendicular to the ground.
What about the 351M/400 thermostats' postitions? Can anyone tell me?
Old Mar 3, 2006 | 05:44 PM
monsterbaby
351m/400 parrelel to the ground and not mounted on the intake but rather on the block itself.
Old Mar 3, 2006 | 06:06 PM
banjopicker66
Sounds easy then. Thermostat locations are as follows:
FE (332, 352, 360, 390, 406, 410, 427, 428): Perpendicular, mounted on the intake (also intake is partially covered by valve cover, as it forms part of valve cavity under the valve cover)
Windsor: Perpendicular (and mounted on the block, I am pretty sure).
351M/400 (And 351C?): Parallel, mounted on block.
385 series (429/460): Parallel, but mounted on intake.
Old Mar 3, 2006 | 06:09 PM
monsterbaby
windsor is mounted on the intake.
