- Anybody else using adjustable fuel regulator on EFI 460?
- 460 1986
- Antifreeze leaking... From where???
- Ford engines
- Smoking 460 & Anti-lock light Q's
- Found D3VE-A2A Heads - Should I buy?
- Stalling When Warm
- What is the biggest stroker kit available for the 460 block?
- CID?
- Mass Air on a 97 460???
- General rebuild questions for the 460
- BigBlock in a 99 ??
- MASTER CYLINDER
- 69 Lincoln 460
- Rod Lengths
- yet another bracket question
- 460/429 timing cover....
- how much $ is a 72 stock 460 worth?
- My 67 F100 Ranger (headache, heartache, etc...)
- pistons
- E7TE - F3TE Heads
- Head Interchangability
- 500 HP 460...
- Dual alternators
- Can waterpumps quit pumping while still spinning?
- 429 heads on a 1992 460EFI??
- bad oil pump, rod bearings, or no oil?
- Changing valve seals in 88 F250 460
- head cleaning
- help w/ cheap rebuild on spare engine
