- Can someone help identify this motor?
- 429 Truck pull motor
- Unbelievable!!!!
- 460 flywheel and starter
- Exhaust on 88 460
- Oil Pressure
- Strange idle
- C8VE-E heads
- Carb driping after shut down
- WANTED: 460 stock valve covers with no factory brackets
- What's the limit on turning a 460 crank?
- 752hp 660 Lbs of Torque out of 2 bolt 429/460 block
- what manifold?
- 460 testing compression
- Emissions Legal 460EFI headers
- 429 balancer
- 20W50 oil okay for new 460?
- 4.10s with 39s??
- Stainless Steel Valve Question
- new hot air choke?
- low buck mods for my 83 460, advice please
- What type and brand of extended capacity oil pan?
- 1994 EFI460-roller cam?
- Which cam profile to use?
- mix-match 460
- break up problem
- 460 Build Cost
- ? About SVO Siamesed 460 Blocks
- How much for a Pair of headers
- 460 stroked
