- my 460 buildup (i got questions)
- Stock 1979 460 HP
- 460 efi vs. carb
- Engine Combo
- DOOE-R heads
- installing distributor in the right position
- gear drive question........
- 1991 4x4 302/Mazda 5sp to 460/E4OD
- 460 Rear motor plate?
- Pop goes the ignition and other children's games...
- 460 Intake gasket
- Need help put the engine together!!
- Rear Main Seal Leaks a drop every few of mins.is this common?
- engine test stand pics.....
- O2 sensor in 1990 F350 - 460
- Redline and a separate question
- What low buck upgrades can I do? (460)
- 77 460
- question about oil pressure
- D3VE's vs. C8-D0VE's assuming equal CR?
- Since my smog heads are coming off...
- 4 bolt main
- 460 questions...
- distributor stuck!
- help me please!!!!!!!!!!!!!!!
- cam selection
- 460 tuneup info
- 460 mileage?
- 460 coolant leaks
- Are there different 460 blocks as far as motor mount bolt patterns go?
