Motor I.D
Old Apr 4, 2002 | 10:28 AM
OwenB's Avatar
OwenB
Motor I.D
I just purchased a parts truck, small v-8 and 4 speed not original.
I think it is a 289 but I need help being certain and have no idea what year it might be or what I need to know to get the right parts.
This is what I have so far...
On the intake manifold- C40E
engraved tag on the intake manifold reads like this...
289 65 7
5-C 550-J
on the block, driver side rear just above oil pan in a circular pattern, and I am not sure where it starts- 3.1975 (date?)
on the block, passenger side rear above oil pan it looks like this
CSDE 8015-C could be 6015-C
All help is appreciated, Thanks. Owen
Old Apr 4, 2002 | 11:27 AM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
Motor I.D
Hey Owen,
If no one has monkeyed with it internally, it appears you have a 64-65 vintage 289. A very good engine indeed. If you don't plan to keep it, it should sell very well. If you do intend to keep it, and it's in good shape, tune it up and it will provide years of trouble-free service. 289- "absolutley one of Ford's better ideas!"
Chuck
Old Apr 4, 2002 | 01:07 PM
sauerf100s's Avatar
sauerf100s
Motor I.D
How many bolts hold the bell housing to the engine? Early 289"s only had 5. Anybody know when they went to 6?
Old Apr 4, 2002 | 04:24 PM
Matt_W's Avatar
Matt_W
Motor I.D
my 1967 289 has five so they might have went to six when they switched to a 302. It still bolted up to a 6 bolt housing though so i wouldnt worry about that one bolt too much.
Old Apr 7, 2002 | 12:08 PM
OwenB's Avatar
OwenB
Motor I.D
So which letter in all of this is the engine code?
Old Apr 7, 2002 | 02:03 PM
pcmenten's Avatar
pcmenten
Motor I.D
>original.
>the right parts.
>289 65 7
>5-C 550-J
>(date?)
>like this
Owen,
Sounds like a 65 289. The C4OE is a 1964 casting number ( C=196X, so C4 is 1964), and the CSDE is really C5DE and that's a 1965 casting number. Is this a 4bbl engine? The letter -C keeps appearing, so that could be a
'C code' 289 4bbl.
As the other poster noted, this will have the early bell housing bolt pattern.
Best regards,
Old Apr 7, 2002 | 07:59 PM
78bronco's Avatar
78bronco
Motor I.D
jon_owens
2004 - 2008 F150
Mar 4, 2015 07:52 PM
PJRay
Oct 21, 2012 11:51 AM
ztmike
17
Nov 17, 2009 02:06 PM
fastmover
N. California Chapter
Mar 30, 2008 12:58 AM
1979 Ford
18
Mar 27, 2006 07:56 AM
