If your carb has electric choke, check to see that the electric housing is indexed properly. There should be an arrow with a couple marks before and after on the housing and a mark on the carb (or the other way around) and should be lined up.
is the choke a stand-alone unit or is it controlled by a relay or something? it has one air tube from the block, an electric wire and two adjustment screws- how do you adjust them to perfect settings or is it a one on one kind of thing?
