diagnostic codes 327,328,332
Thanks in advance for all the help.
Sam
328 is exhaust gas recirculation valve position sensor closed voltage lower than expected.
332 is insuffient flow to EGR valve. Check to see if you have vacuum to the EGR valve at increased RPMs.
>voltage.
hey Swirk! maybe you can answer this question -maybe you have already. My truck is getting code 31 (like the 327 code) and i have no vacuum at the EGR at idle nor do i have vacuum (that i can feel with my finger) when i rev up the motor while sitting in park. my question in another post was: should there be vacumm to the EGR at a high rev? (no responses yet). Because i do not have any vacuum at high revs i am assuming that the EVR (EGR regulator) is fried. what do you think? I replaced the green hard plastic hose from the EVR to the EGR already so that vacuum line is good now. CHUCK ENGINE light on constantly. any tips?
thanks,
Rusty.
I had no vacuum at idle or revved up at my EGR. I had a 332 code on constantly. I fixed that. I now have about 5-6" of vacuum at 2500-3000 rpms. I would suggest tracing your vacuum lines. There should be three red lines off of the intake manifold. I traced those three lines first. One went to the fuel pressure regulator, another went to a T fitting and the third someone had plugged into the "coffee can", which had a black line coming out of it. What I ended up doing is connecting the third red line and the black line together (with a small piece of hose and a couple of hose clamps), this made the vacuum start working at my EGR valve.
My suggestion would be to trace your vacuum hose routing, by using the sticker under the hood. It is color coded and is very helpful. If you unplug the big black line that goes from the MAP sensor to the manifold, the truck will stall.
