ignition timing
Old Apr 6, 2002 | 05:46 PM
78bronco's Avatar
78bronco
ignition timing
i have an 84 f-250 with a 351w, the little sticker says that i need to disconnect a single wire/black connector to check timing. where is this, and what does it go to?
Old Apr 6, 2002 | 06:20 PM
StangMan's Avatar
StangMan
ignition timing
Single wire? Carbed or EFI? On the EFI engines, there's the SPOUT conector, which you have to disconnect when the engine's turned off to set base timing. If you follow the wires from the TFI connector back along the intake, you'll feel a little connector sticking out of the wire bundle. You just pull the "pill" out of the connector, and you're set to check the timing.
The only thing I can think of on a carbed engine would be the vacuum spark advance line, which you disconnect and plug to check the timing. It's also a good time to see if you're spark advance is functioning. But it's not a wire, it's vacuum line.
Hope that helps,
Ben
Old Apr 7, 2002 | 11:28 AM
78bronco's Avatar
78bronco
ignition timing
its carb and theres no vac line to the distributor. only the wires to the module. the sticker on the truck says to disconnect a single wire with a black connector.
Old Apr 7, 2002 | 07:59 PM
78bronco's Avatar
78bronco
ignition timing
where is the metal sign with the timing numbers?
Old Apr 7, 2002 | 09:40 PM
stover007's Avatar
stover007
ignition timing
Kev1180
Large Truck
Sep 2, 2015 03:56 PM
SUPERDUTY_untouchabl
45
Nov 29, 2014 12:26 PM
riverguideguy
May 13, 2013 09:33 PM
fixnair
User Gallery & Picture Display
16
Dec 28, 2009 08:54 PM
Feeop
Aug 6, 2004 01:07 PM
