oil pressure dropping
Old Jul 12, 2004 | 12:34 PM
wookiepompitus's Avatar
wookiepompitus
I got 89 F-150 with a 302 v-8 recently its been dropping oil pressure when i go to a stop and also the engine light comes on. but when i hit the gas and start moving the oil pressure is fine. i checked the oil to see if it was low on oil yesterday and there was some oil leakage looked like comin from the valve cover. i think maybe its my valve cover gasket, ive also heard it might be that my head is cracked or my head gasket is screwed up id thought id post somethin to see if i can get some opinions on my problem before i start tearin into it.
Old Jul 12, 2004 | 04:09 PM
MustangGT221's Avatar
MustangGT221
Does the oil pressure stay normal when you first start the engine, and then once it's warmed up..the pressure will drop down?
These engines should run between 40-60psi of oil pressure at idle. If an engine drops pressure at idle when the engine is warm, that means the bearings are worn and the engine will need a rebuild soon. When the engine gets warm the oil thins out and fills in the gaps/spaces of the bearings/engine better which causes you to loose the pressure. Changing the oil pump doesn't help...only a rebuild. Using a thicker oil will get a little more lift out of the engine.
Old Jul 12, 2004 | 05:29 PM
daerhldgs2's Avatar
daerhldgs2
you need a mechanical or alternate gauge as the ford gauges are only idiot lights and read pressure if there is more than 8 lbs. and read nothing if there is less. So spend a few bucks and hook up a mech. gauge and find out before you spend a lot.
Old Jul 12, 2004 | 05:30 PM
daerhldgs2's Avatar
daerhldgs2
the head gasket has no connection to the oil pressure!!!
Old Jul 13, 2004 | 02:55 PM
wookiepompitus
when i start the engine when its cold it does alright and then it drops down when it gets warm. im gettin ready to put on the mechanical gauge to see if my stock gauge in my truck is screwed up
Old Jul 14, 2004 | 12:08 PM
daerhldgs2's Avatar
daerhldgs2
sounds like worn bearings -probably not the oil pump -they run in oil, can get scored from dirty oil but seldom wear out.
Old Jul 25, 2004 | 11:16 PM
dommer's Avatar
dommer
I have the same problem. When you say that this is caused by the bearings being worn, do you mean cam Bearings, rod Bearings, or main Bearings?
Old Jul 26, 2004 | 08:57 AM
daerhldgs2's Avatar
daerhldgs2
you probably have general wear in your rod and main bearings cam bearings will usually last 1 to 2 rebuilds.
Old Jul 26, 2004 | 09:24 AM
dommer's Avatar
dommer
I've found a few rebuild kits online, ranging anywhere from 350ish to 600 bones. Is any one better than any other? Is there a brand which makes better stuff? Any recommendations?
Old Jul 26, 2004 | 10:53 PM
sty's Avatar
sty
I missed the oil change...
And after about 8000km on my 301000 km (180000 miles)now ex F 150 w/302 , sold it yesterday my oil pressure did the same thing , changed the oil and filter , (oil was dirty) I think the filter was plugged restricting the oil from flowing. Only time it did it after that was after towing a 4000# TT.At idle oil pressure would go down like yours only after she was good and hot from towing. After letting it cool down for a half hour or so , it would be fine.
Probably is bearings?
Good luck
Sty
Old Jul 27, 2004 | 09:39 PM
wookiepompitus
got it fixed found out timin chain cover was cracked lettin anti freeze and water in the oil makin the oil thin and milky like. replaced that it was fine.
Old Jul 28, 2004 | 08:53 AM
daerhldgs2's Avatar
daerhldgs2
antifreeze and water don't make good lubricants, keep an eye on it as you may still need new bearings. good luck!!
Old Aug 1, 2004 | 11:13 PM
dommer's Avatar
dommer
I changed the oil and filter, put in 20w50, and drove around for about an hour, the pressure stayed in the normal range.
Michael Hoersten
Mar 3, 2014 07:52 PM
tproffitt1
Escape & Escape Hybrid
Feb 28, 2013 05:47 PM
TrevorP
Feb 18, 2007 12:29 PM
sprocket226
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 4, 2003 01:54 PM
faskar
1978 - 1996 Big Bronco
Apr 23, 2001 12:10 PM
