Hey All,
Got a 1988 351w, Got a leak coming from what looks like behind the starter. Can't really tell. Comes from behind the starter and drips down off the transmission bell housing.
I need to know if there is a freeze plug in that area that I can not see until I remove the starter? or could it be coming from somewhere up above that i am not considering?
Only leaks when the truck is running and its a consistent drip, kinda like what you would see from a car with the AC on.
Theres a freeze plug that is right at the front of the starter, but it is visable. I would try RTM's advice and clean everything off real good and then try tracing it down.
Thanks guys for the quick response. The heater core is bypassed so its not coming from there. I guess i'll take RTM's advice and try to clean it up. One question though.
How long does the system take to develop pressure? As soon as the engine fires the drip appears within 10 seconds. Do you think it could still be a head gasket. I hope not, thats beyond my shade tree experience
i'm leaning to head gasket like 94f150 said but for fun start it up and when it starts dripping put your hand on the back of the head right where the intake meets the head. i have seen a couple of blown out intake gaskets.
the last two i had come in blew out the intake gaskets right on that same corner. when we put a straight edge on the intake i had to pull out the tape not the feeler guages. any one know why? i have heard from a few other guys about the same problem.
Don't know why but I have experienced several oil/water leaks from the back of the stock intake. And they are a real pain to get to reseal once they start leaking. On the other hand Edelbrock performer intakes seam to seal real nice. Wink wink, nudge nudge.
What you had yelowjeep is electrolysis, this is not the antifreeze eating the maniford but a electrical reaction generally associated with dissimilar metals in contact with each other. One thing to be certain of is good grounding between your frame, engine and batterty to help eleminate this problem. If you still have problems, look further to dissimilair metals in contact with each other, sometimes someone has plumbed a copper or galvinized iron fitting of some sort to your aluminum manifold. If you still end up with problems, there is a company that manufacurers a radiator cap with a replaceable sacrificial zinc anode attached that would get eaten first in the electrolisis process, thus you replace the anode rather than an expensive manifold or timing cover.
I am very familiar with electorlysis. Over time coolint can become acidic or alakaline, either of which is corrosive to nonferrous metals and creates a slight electrical charge. You can check this by using a voltmeter and testing your coolant. A reading of 0.2V is acceptable 0.5V is borderline and 0.7V or higher, your coolant should be flushed. But the solution i suggest is that we stick to topic, which in this case is a coolant leak and has nothing to do with electrolysis.
EDITED FOR CONTENT We do not need to start name calling or threatening! Wiz427
Listen Jellowjeep, I was trying to help out here with your problem, my manifods dont leak or get eaten, as I have taken the proper steps to prevent that from happening. Thats too bad about your manifold, its really the pits that a six dollar bottle of antifreeze could have prevented that, this is why preventative maintaince and taking the proper steps to insure that electrolysis doesnt cost you an entire manifold or timing cover are always done to your rig!
We dont call names on here yellowjeep, this is a family site and I have no idea whatsoever why you would take offense to nothing more than a suggestion to keep that from happening!
Also, threatening someone can lead to a knock at your door my friend, its not legal !!
First of all 94f150-408 I was not threatening you. Secondly my offense comes from people like yourself who feel that they know everything and are presumptuous in their comments thinking that others know nothing. You are helping to prove my point by presuming that the leak was caused by my own neglect. You don't know me or my truck or when i purchased it or anything. That, "friend", is why i suggest that you stick to topic and don't try to solve a problem that wasn't asked or ever present for that matter.
