flywheel - resurface?
Old Jul 16, 2004 | 08:04 PM
88grandmarquis's Avatar
88grandmarquis
Got an estimate on clutch work today. Roughly $570. They said that if I have the new clutch kit installed, the flywheel has to be resurfaced. Can anyone explain that too me? I've never heard of the flywheel being resurfaced.
Old Jul 16, 2004 | 08:58 PM
f100guy's Avatar
f100guy
it gets rid of hot spots and minor imperfections of everyday usage of the clutch. it is pretty cheap and reccomended. you know how you can get a brake rotor turned to get rid of the grooves. it is just like that
Old Jul 16, 2004 | 09:14 PM
88grandmarquis
Thanks for the info.
Old Jul 17, 2004 | 03:46 AM
200000+F150's Avatar
200000+F150
Did a clutch a while back and being tight on money, I didn't resurface flywheel because it didn't look too bad, and had never had one before. The clutch started slipping after a few thousand miles and I had to tear in again. The flywheel was glazed and surface showed uneven wear. Surfaced this time and works great. Don't skimp!
