650cfm vs 600cfm
Old Jul 10, 2010 | 05:26 PM
david00f150's Avatar
david00f150
650cfm vs 600cfm
Just got my 302 back in my bronco and got the timing set. Trying to get the air/fuel mixture right but its still running rich. Its a holley 650 double pumper. I have put the smallest jets in the holley jet kit on the carb and my plugs arent the right color when I pull them out.
My question is would stepping down to a 600 be that much of a difference or would I be wasting money. If so what carb do most of ya'll run on your rigs? My motor is somewhat built: Edelbrock performer intake, ported E7 heads, 204/214 cam, hedman long tubes.
Old Jul 11, 2010 | 07:34 AM
roadrash63's Avatar
roadrash63
hey
im thinking that is the double pumper is killing you .
they are made for the track
if i remember right you can adjust when the secondaires open and when the
2nd accelerator pump works.
hows your power valve?
idle mixure screws ?
how does it run?
Old Jul 11, 2010 | 09:59 AM
Old Hickory's Avatar
Old Hickory
You'd be much better off with a vaccuum secondary 600cfm carb on your truck than a
double pumper. As mentioned above the double pumpers are primarily very high performance type carbs for hot street cars or race cars.
61steven
May 14, 2016 09:58 AM
V8orBUST
Jun 23, 2015 08:41 AM
WilliamKG88
Jun 18, 2015 05:24 PM
sony420
Mar 29, 2015 12:54 AM
rhetor
Oct 7, 2009 10:39 AM
