Hard starting when cold
Old Dec 30, 2010 | 07:28 PM
econoshorty's Avatar
econoshorty
I have an 1989 E150 4.9 FI when it's cold it is real hard to start the battery is strong and turns the engine over fine but it won't fire at all the first two or three tries then on the fourth or fifth attempt it will start to fire and chug a little but not enough to get it going when it finally does start it runs rough for a moment then runs and starts fine. I tried cycling the fuel pumps on and off before trying to see if it was fuel pressure but it didn't help. Thanks
Old Dec 31, 2010 | 01:39 PM
Ranger GT2's Avatar
Ranger GT2
Have you tried to check and see if it has fuel pressure with a gage at start up? You need to narrow it down if it is fuel or spark related.
Old Dec 31, 2010 | 02:28 PM
econoshorty
Checked the pressure on the rail it didn't have any pressure with the key on and there was air in the rail after the air was bled off it had 60 psi and started right up. How is it getting air in the rail ?
Old Jan 2, 2011 | 07:42 PM
dustybumpers's Avatar
dustybumpers
clean the termanals on the fuel pump relay, that's what I did, now mine starts like it always did
jd58980
23
Aug 29, 2022 11:55 AM
Cperk
Jan 2, 2017 12:21 PM
zdumpor
Aug 22, 2016 09:46 AM
frankenstein f-150
Oct 19, 2009 06:32 PM
foxracing0934
Aug 19, 2008 09:48 PM
