quick intake question
Old Jan 1, 2011 | 10:40 PM
c.l.nye's Avatar
c.l.nye
how well will a single plane 4 bbl intake work on a stock eng?
Old Jan 2, 2011 | 09:26 AM
c.l.nye's Avatar
c.l.nye
any one? I am trying to decide between a offey 4bbl DP with a 500 cfm 4bbl or a offey single plane with a 2bbl. any ideas or sugestions? thanks chris
Old Jan 2, 2011 | 10:08 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Works pretty well on mine.
c.l.nye's Avatar
c.l.nye
which set up?
Old Jan 2, 2011 | 09:48 PM
80broncoman's Avatar
80broncoman
The dual port is mainly for an otherwise stock engine. If you reallywant performance you can feel you need to go with a different manifold.
I have a Offy C and 500cfm 4bbl on mine and it works well.
Old Jan 3, 2011 | 07:33 AM
c.l.nye's Avatar
c.l.nye
thanks, I guess I will go with the offey C.
Old Jan 3, 2011 | 10:23 AM
AbandonedBronco's Avatar
AbandonedBronco
I have two Broncos with 300s. One has the Offy DP with a 390cfm and the other has an Offy C with a 600cfm (not my choice, just what came on it).
Both work very well. The Offy DP seems to offer a little more low end "snap", and in theory should deliver better mpg. The Offy C seems like smoother acceleration, and I can definitely feel the difference at higher RPMs.
However, to be honest, I can't say how much of that is because of the gear difference (3.00 and a 3.55), or the carb size difference.
I like both though, and wouldn't hesitate at either.
My favorite thing about the Offy C is the ability to mount the carb in any direction. With a DP, the 4bbl can only go on ONE WAY. The C offers any configuration. May or may not make it easier for your own custom accelerator bracket. (Something to keep in mind, because you need to come up with your own.)
Old Jan 3, 2011 | 03:13 PM
c.l.nye's Avatar
c.l.nye
AB, thank you for the input. The acc. cable is nobig deal for me,I am fairly good at fab work. I plan on going to a bigger cam and head work later on,so the "c" seems like the logical choice for me.Plus it can be used with a 2bbl if I so choose.
Old Jan 3, 2011 | 03:19 PM
AbandonedBronco
Very true. The DP can't be used with a 2bbl.
Well, it can, but it'd be a real mess.
With a cam and headwork, the C would probably work quite well for you.
Old Jan 3, 2011 | 03:45 PM
c.l.nye's Avatar
c.l.nye
thank you for the info. chris
Old Jan 3, 2011 | 05:21 PM
BaronVonAutomatc
Be sure to fab up a plate to plumb heat to the bottom of the manifold (if you're planning on heating the bottom of your manifold, and you should) and mount it before you install the manifold. I'd fab the throttle cable bracket using the same two holes in the manifold through which the heating plate is secured as the mounting point while it's off too. Especially with a 2-barrel, otherwise you'll need to modify the existing or get a new cable.
Old Jan 3, 2011 | 09:14 PM
1eyedjack's Avatar
1eyedjack
Abandonedbronco.. How did you fab up your kickdown lever for your trans? I just did the offy DP with the 1403 edlerbrock.. I wanted to see what other people did with their kick down.
BTW. I did the header, offy intake and the 1403 edlerbrock card. it woke her up.. Im thinking bout doing the mild P&P with a comp cam.. just gotta somehow talk the wife into letting me.. LOLOLOL
Old Jan 3, 2011 | 09:37 PM
AbandonedBronco
Mine's a manual, so I didn't need the kickdown linkage. May want to send F-250 Restorer a PM and ask him, since he has a C6.
Old Jan 3, 2011 | 11:34 PM
dwrestle's Avatar
dwrestle
AB I'd be willing to bet the extra power in the higher RPM range is due to the bigger carb more than anything. I got a DP, and I had a big QJet on there(750cfm), and it would probably rev way over 5k RPM if I let it.
Old Jan 4, 2011 | 02:00 PM
AbandonedBronco
My 390cfm / DP will rev that high too pretty easily.
I was meaning more at higher speeds/rpms. The DP seems to have a more difficult time accelerating and holding higher speeds than the C. Again, it may be other components that do it.
