Need help
Old Aug 20, 2011 | 01:21 PM
WildlandFirefighter's Avatar
WildlandFirefighter
Need help
My fuel relay isn't clicking on my Bronco with a 300I6 but the ECC is clicking. My fuel pump isn't working.
What can cause the relay from not clicking?
Old Aug 20, 2011 | 01:56 PM
WildlandFirefighter
We hooked a wire up from the battery to the relay and the pump came on...must be a short somewhere?
Old Aug 20, 2011 | 01:57 PM
91Bronc300's Avatar
91Bronc300
First place to look is the inertia switch. Google ford inertia switch to find out what they look like. Look for yours on the firewall above the pedals or behind the passenger kick panel. Push the red button down if it's popped up. If it's popped up, that's your problem.
Old Aug 20, 2011 | 02:07 PM
WildlandFirefighter
No, it hasn't popped up. Checked that the first thing today.
Old Aug 20, 2011 | 02:42 PM
91Bronc300's Avatar
91Bronc300
I guess you've checked all the fuses too. Can you try switching the ABS and fuel relays for each other?
Old Aug 20, 2011 | 02:46 PM
WildlandFirefighter
There is no fuse for the fuel in the fuse panel box.
We found the problem I think.
The thick yellow wire on the fuel relay terminal. Where does it run?
We ran a wire from the battery to it and the truck cranked up like it suppose to.
Is the ignition switch bad?
Old Aug 20, 2011 | 03:55 PM
91Bronc300's Avatar
91Bronc300
I'm not sure if that means your ignition switch is bad or not. And I don't own an EEC-IV vehicle anymore. But these are out of a 91 service manual. I hope they can be helpful. The wiring diagram is for the F-series/Bronco.
WildlandFirefighter
1978 - 1996 Big Bronco
Aug 20, 2011 03:01 PM
hayou89
1983 - 2012 Ranger & B-Series
Feb 29, 2008 09:39 AM
gov2mod
Aug 29, 2004 01:38 PM
BobcatSteve
Jan 20, 2003 08:59 AM
lurch
Sep 4, 2002 10:44 AM
