starter relay failure
Old Aug 21, 2011 | 07:30 PM
rustywheel68's Avatar
rustywheel68
i ran into an interesting issue today, and just want to see if anyone else has seen this.
i went out to start the truck for the first time in a month or two. of course, i killed the battery trying to get it fired up. no big deal, i hardly ever use it, so this happens a lot.
there was some corrosion, so i decided to pull the battery out and clean everything up.
here's where it got interesting-
i reattached the positive battery cable. when i went to reattach the negative cable, i got a pretty good shower of sparks. i leaned into the cab to make sure the key wasn't in the ignition- it wasn't.
attempted to put the cable on again- more sparks, and the starter tried to kick over. what the??
i removed the positive cable, and put my voltmeter across the main studs on the starter relay- and sure enough...its OPEN. with no power at all.
it had been working fine five minutes before- its never given me trouble. its about 2 years old, a $25 NAPA relay, not some cheap part.
i would never have expected it to fail at all...but much less to fail *open*.
anyone else seen this?
Old Aug 21, 2011 | 08:08 PM
Vanaroo's Avatar
Vanaroo
I had one go out this weekend, too. It was only a few months old. The quality of replacement parts really sucks these days.
tstape
Nov 25, 2017 04:59 PM
strokerfe
Sep 28, 2011 04:41 PM
LARIAT 85
Sep 24, 2011 03:04 PM
CherryColaholic
Bronco II
Jan 27, 2005 08:10 AM
oldbluebronco
1978 - 1996 Big Bronco
Oct 8, 2004 10:39 AM
