Bellhousing pattern
Old Feb 21, 2002 | 08:15 PM
mwellner's Avatar
mwellner
Bellhousing pattern
I have a 1996 Bronco with 302 with E4OD, and I heard that a 96 351 doesnt share the same bellhousing pattern, is this true or not, I have heard the opposite
Old Feb 21, 2002 | 08:56 PM
351Inside's Avatar
351Inside
Bellhousing pattern
Both small block, therefor same pattern.
Old Feb 21, 2002 | 10:23 PM
TorqueKing's Avatar
TorqueKing
Bellhousing pattern
you can ckeck if you can reach the top two tranny bolts. If you can touch them at the same time with one hand (middle finger on one and thumb on the other), then you have a Small block pattern. If they are too far apart, then you have a Big block pattern, like the 351 Modified. Good luck, John
Old Feb 22, 2002 | 12:14 AM
TorqueKing's Avatar
TorqueKing
Bellhousing pattern
scottie2hottie
18
Sep 2, 2019 09:52 AM
AmeriKen
Flathead V8 & Flathead 6
Aug 23, 2012 06:02 AM
superdutyjoe
Modular V8 (4.6L, 5.4L)
Sep 17, 2006 12:18 AM
stats2me
Nov 4, 2005 08:26 AM
351coupe
Nov 13, 2002 08:17 PM
