e5te heads
Old May 2, 2006 | 09:35 AM
uncle junk's Avatar
uncle junk
Smile e5te heads
are e5te heads stock on a windsor ho if so how much difference is there in power from a windsor with e7te heads
Old May 3, 2006 | 12:12 PM
uncle junk's Avatar
uncle junk
wow soo many responses i cant fit them on one page
Old May 3, 2006 | 01:09 PM
Kemicalburns's Avatar
Kemicalburns
i have no idea. in stock form i do believe the e7's are better but couldnt say how or give numbers. have you searched the web?
Old May 3, 2006 | 02:16 PM
uncle junk's Avatar
uncle junk
yeah very little info on the difference besides valve sizes .
Old May 4, 2006 | 09:15 PM
f100guy's Avatar
f100guy
is this a 351 or 302. the e7 head will get you more power for sure on a 302 if this is a 351 don't bother because the e7 for a 302 is to restrictive as it is
Old May 5, 2006 | 06:06 PM
uncle junk's Avatar
uncle junk
it is a 351w it had e5te heads on it and i had a pair of e7 from a 5.0 machinedup and put a crane cam in it for my new build its carb as well if that makes any difference
Old May 5, 2006 | 07:00 PM
f100guy's Avatar
f100guy
i think e7's will hold you back if they came from a 302 unless you do some porting an pollishing to them. they blow for 302's and would really suck on a 351. go to this site and check out his e7 heads. i bought a set and they flow way better and realy look good. www.thumperoforangepark.com
Old May 6, 2006 | 04:12 PM
uncle junk's Avatar
uncle junk
i had some serious port and polishing done to the heads they should be sweet now ill no in another month or so before im done with the truck
Old May 6, 2006 | 06:42 PM
f100guy's Avatar
f100guy
you also need to drill the holes out on the heads because the head bolts on a 351 are thicker than the 302 head bolts are.
Old May 6, 2006 | 08:48 PM
uncle junk's Avatar
uncle junk
already done i had to actual send them back cause they forgot to drill out the outer rows on bolth heads what a nite mare
Old May 7, 2006 | 12:28 AM
RacinNdrummin's Avatar
RacinNdrummin
The E5 heads have more restrictive exhaust ports as opposed to the E7's with a larger "thermactor-bumps". Intake ports are the same and I think the combustion chambers are bigger at like 64cc's. Aside from the vintage 351 windsor heads and the gt40's on the fox-chassis cobra, the E7 heads are the best windsor casting. After 1977 351w used the same heads as the 302 eccept for the bigger bolt holes. The e7's will work fine on the 351, they are way better than the E5's.
Old May 7, 2006 | 12:00 PM
uncle junk's Avatar
uncle junk
thats what i wanted to know i have four different trucks with 351w and they all have had e 5 heads all 80 s vintage trucks and motors
Jimmie MORGAN
Mar 22, 2008 09:48 AM
bivens1172
Mar 29, 2006 09:39 AM
lisagoud
Oct 15, 2004 04:24 PM
strangebrue
Mar 20, 2004 10:54 PM
RanDawg
Jan 29, 2003 09:22 PM
