Windsor Intakes
Old May 1, 2006 | 03:55 PM
FE Man's Avatar
FE Man
Windsor Intakes
I have a 85 windsor that is all stock. Other than headers maybe a 4x4 cam, aluminum intake and 4v carb it will be stock. I was wondering if the edelbrock performer rpm ports would be bigger than the ones on the heads. If they are and need porting i will just use a performer or a weiand stealth. But if the ports line up with the performer rpm I will use it but I'm sure it wont. Just wanted to get your guys' opinion first.
Old May 1, 2006 | 04:40 PM
Kemicalburns's Avatar
Kemicalburns
since its a 4wd go with the weiand stealth. offer great torque. you open it up to much and your power range will move up higher in rpms which isnt good for your application
Old May 1, 2006 | 06:15 PM
FE Man's Avatar
FE Man
Yeah thats what I was thinkin, the stealth is a pretty good overall intake. My buddy has one on his 460 and it pulls pretty hard. I'm sure the ports would match up better on the stealth than the performer rpm to huh?
Old May 2, 2006 | 09:28 AM
uncle junk's Avatar
uncle junk
i ran the edelbrock performer rpm on my windsor it was the ***** .i had the intake and the cam i put the rpm aluminum heads but they went junk on a really good over heat job but now im running e7te heads with the rpm series manifold and a smaller cam and it works just as well i didnt have to port anything for the fit but i did the heads up anyway
lasthighboy
Oct 21, 2009 10:24 PM
3D52
Jul 26, 2008 10:09 AM
lance65
Dec 19, 2006 05:35 AM
76 F250 4X4
Nov 29, 2003 07:19 PM
curtis1783
Feb 14, 2001 06:36 PM
