Total Timing A 302!
Old Aug 4, 2006 | 03:12 AM
markal's Avatar
markal
Total Timing A 302!
Hi, could you guys tell me what the total timing should be, i have a mexican block 302 with comp cams xe268h, world prod windsor snr heads, mallory duel points, sealed power domed pistons, 600 vac secs holley, etc, i have marked the pulley, what next! is it checked with the vacuum disconected! what hp do you think i should have! also what plug gaps! all help appreciated regards Alan.
Old Aug 4, 2006 | 06:24 AM
ken75ranger's Avatar
ken75ranger
most guys run 36-38 degrees total timing. I check it with the vacuum plugged in to get the total timing. Your plug gap should be detremined by your ignition system. Since you list a dual points set-up I'd say 35-38.
Old Aug 5, 2006 | 12:28 PM
markal's Avatar
markal
Thanks, just what i wanted to know, regards Alan.
Old Aug 8, 2006 | 09:18 PM
shooter05's Avatar
shooter05
grados de thirtysix
sorry couldn't resist
postalxj
48
Apr 19, 2017 02:28 AM
underthebridgejim
Mar 8, 2017 06:28 PM
1981 convert
Feb 21, 2016 02:06 PM
Adam Spurgeon
Jul 31, 2015 08:33 AM
Dannym
Dec 12, 2004 06:26 PM
