393 stroker problem
Old Aug 5, 2006 | 09:21 PM
FordPerf300's Avatar
FordPerf300
393 stroker problem
For a while i have had a problem of excessive blowby on the 393. After doing a compression test cyls 5 and 7 have 95 psi and the rest have 210. I just pulled the cyl head off and noticed what looked like water spots on the cyl wall of cyl 5, the piston was all the way up on 7 so i didn't even check that one. But this is what it looks like, sorry for the bad pic.
http://img.photobucket.com/albums/v1...Picture113.jpg
any Ideas?
Old Aug 7, 2006 | 08:38 AM
Kemicalburns's Avatar
Kemicalburns
pic isnt available. you may have had a gasket blow internally. ive seen them go that way vs out the side which of course is more noticable. how did the rest of the gaskets look on the lower intake to head surface etc... what was the block bored to, any port work on the heads?
Old Aug 7, 2006 | 04:04 PM
FordPerf300
block is 4.030 no porting on the heads, they are windsor jr. Head gasket looked fine, all mating surfaces looked fine. sorry bout the pic, i deleted the old one and got a better pic, forgot to update the link http://img.photobucket.com/albums/v1...Picture114.jpg
that should work
Old Aug 9, 2006 | 11:18 AM
gofast68's Avatar
gofast68
I'd bet on the head gasket. I can see antifreeze in the picture. The only places that antifreeze can get into the cylinder are from a headgasket, cracked cylinder head or cracked cylinder wall. If the heads aren't ported and new, then not very likely. I don't see any obvious cracks in the cylinder wall either. You can always have the head checked at a machine shop for leaks. If nothing shows up, it was most likely the head gasket. Replace and try again.
Old Aug 9, 2006 | 04:54 PM
FordPerf300
The antifreeze is from when i pulled the head off. The spots on the cylinder wall are aluminum deposits, from the 12:1 compression this engine was seeing. Time for a hone and some 17cc dish pistons...
FordPerf300
25
Dec 29, 2007 03:46 PM
FordPerf300
Sep 7, 2004 04:37 PM
FordPerf300
Jan 12, 2004 10:52 PM
FordPerf300
Oct 25, 2003 10:48 PM
FordPerf300
1978 - 1996 Big Bronco
Oct 2, 2002 11:02 AM
