broken valve or ???
Old Aug 9, 2006 | 03:22 PM
fordpower88's Avatar
fordpower88
broken valve or ???
I have a '93 f-150 with the 5.0/ auto with 143000 miles on it. I am trying to figure out what is goin on with my number 8 cylinder. I thought I had a bad ring because I had no compression. I squirted some oil in the cylinder and the compression came up from 35 to about 50 psi. So now I am thinkng a valve. But wouldnt I be able to see a broken valve or a broken spring? I am stumped on what to test or look for next. If it is a ring I want to just swap out the motor but if it is a valve I would just fix it. Any thoughts or help would be great. Thanks!!
Old Aug 9, 2006 | 03:34 PM
MustangGT221's Avatar
MustangGT221
When the compression increases with oil being put in the cylinder it usually means the rings not the valve.
The #8 is known for prematurely going before the other cylinders on a 5.0 because the PCV is mostly drawn into that cylinder.
You might need a rebuild.
Old Aug 9, 2006 | 04:39 PM
P51D Mustang's Avatar
P51D Mustang
Number 8 is the problem cylinder quite ofton. Another theory as to why, has been traced to the number 7 and number 8 ignition wires cross firing. This causes a pre-iginition in number 8. I always make sure the those wires are good and are well seperated.
Too bad, but I also think you will need to rebuild the motor.
Old Aug 10, 2006 | 10:45 AM
derherr65's Avatar
derherr65
35psi? My low compression 400 builds 135psi. My 289 made 155psi. I think your number alone tells the story; major wear and blowby, time for a rebuild
