Valve covers question...
Old Mar 4, 2007 | 12:31 AM
Jrock909's Avatar
Jrock909
I have been told that the early 80's Crown Vic's used the same valve covers as 93-95 Cobra Mustangs? Now is this true, because I can get a set of Vic valve covers dirt cheap. Main thing is that I will have a set of free valve covers that will clear 1.7 roller rockers without grinding or removing the baffles....
Old Mar 4, 2007 | 01:12 AM
LxMan1's Avatar
LxMan1
Early 80's Crown Vic's used the standard stamped steel valve covers. They look about thae same as all of the earlier non-EFI covers. They just han extra mounting tabls on the top of them for EGR solenoids and such. 93-95 Cobra Mustang Valve covers are aluminum.
Old Mar 4, 2007 | 09:22 AM
baddad457's Avatar
baddad457
The 93-95 Cobra covers were not aluminum. They were a double layer stamped steel cover, painted black. If the Vic covers are free, try them. All that's needed anyway is to dimple the filler hole baffle to clear the rockers. I set my 83-83 GT covers on my 331 the other day with soem baffles I made, taped to the covers. After bolting them down, I pushed the baffle down onto the rocker and it dropped a 1/2" or so before contacting the rocker.
